Throttle body reset procedure
BLACKJKU
Moderator
Lifetime Supporting Member
Huntington In
Step 1: Turn the Jeep to the "on" position but not the engine running position.
Step 2: Wait for all of the dummy lights to turn off (check engine light will stay on).
Step 3: Depress the accelerator REALLY slowly...Driving Miss Daisy with a touch of Cocoon slowly...all the way to the floor.
Step 4: Release the accelerator at the same excruciatingly slow rate.
Step 5: Turn Jeep off.
Step 6: Start engine.
Step 7: Take it on a test drive.
I found that if it doesn't work doing this slowly then try doing it again a little faster. It took doing this 2 different times in order to fix my lightning bolt limp mode problem.
Reactions: Chris and mrjp
I found the option in jscan redid mine through the app
