LED Headlight issue one on high one on low
Bmerrill30
Colorado
Just bought this 2013 sahara moab unlimited, got home and noticed the headlight issue. They are some cheap aftermarket LED drop-ins with an adaptor harness. The issue I am having is when the headlights are on low beam the drivers side is low neam the passenger is high beam. When I turn high beams on they switch to Driver side high and passenger side low. Any thoughts would be greatly appreciated. I am very mechanically inclined but this is my first Jeep and wanted some insight before I start tearing stuff apart.
My guess one set of wires are switched wrong, look to see which one is working right and look at the wires at the connector. Then look at the other connector to see if the colors match up the same.
Reactions: JeepJeezy and WSS
Klingt stark nach einem falsch gepolten oder vertauschten Adapterkabel, das passiert bei günstigen LED-Kits öfter. Ich würde als Erstes die Steckerbelegung checken, bevor du tiefer gehst.
