Is this u-joint too cracked to use?
2008basanti
Ottawa
I just installed this u joint and after pressing in opposite side I noticed the cap is cracked
I wouldn't use inside each of those caps are about 75 pins once one falls out they keep falling out then you will experience severe vibration and a good chance of the shaft dropping too the ground
No good, water can get in there and you'll be replacing it later. I've never seen one crack like that.
