Green Jeep Freak New Member Joined Nov 16, 2019 Messages 9 Location Australia Nov 16, 2019 #1 Anyone have cruise control anti slip issues, cruise control kicks out, orange check engine symbol, anti slip symbol appear on dash
Chris Administrator Staff Member Joined Sep 28, 2015 Messages 32,494 Location Gillette, WY Nov 16, 2019 #2 Either your steering wheel is off center, a bad wheel speed sensor(s), or your tire pressure is off. It's either one of those, or several.
Green Jeep Freak New Member Joined Nov 16, 2019 Messages 9 Location Australia Nov 16, 2019 #3 Chris said: Either your steering wheel is off center, a bad wheel speed sensor(s), or your tire pressure is off. It's either one of those, or several. Click to expand... Was thinking sensor(s), tire pressures are good, not sure about steering wheel of centre, will check that out Cheers Chris
Chris Administrator Staff Member Joined Sep 28, 2015 Messages 32,494 Location Gillette, WY Nov 17, 2019 #4 No problem! Yep, it's likely either your wheel speed sensor(s), or the steering wheel / alignment (or both). Report back if you figure it out.
LCBOYER JK Enthusiast Supporting Member Joined Sep 1, 2019 Messages 167 Location South Texas Nov 19, 2019 #5 Weird things happen if you have crud or salt damage to wheel sensore Reactions: Chris
Bubslipknot101 Member Joined Sep 29, 2019 Messages 30 Location Houston Nov 20, 2019 #6 Green Jeep Freak said: Was thinking sensor(s), tire pressures are good, not sure about steering wheel of centre, will check that out Cheers Chris Click to expand... Is your "ABS" light on too? Usually with speed sensor issues that's a tell-tale sign.
Green Jeep Freak New Member Joined Nov 16, 2019 Messages 9 Location Australia Nov 24, 2019 #7 Update, just put scanner on the jeep Came up as a camshaft sensor Going to replace this, see if it fixes the problem
Chris Administrator Staff Member Joined Sep 28, 2015 Messages 32,494 Location Gillette, WY Nov 24, 2019 #8 Let us know if that fixes it. Hopefully it's as simple as that. Reactions: Green Jeep Freak
Green Jeep Freak New Member Joined Nov 16, 2019 Messages 9 Location Australia Nov 24, 2019 #9 Will do Cheees
